Mirror Bulb Replacement
Chris Kennedy
Houston, Texas
The map light on the right side of the inside mirror on my '89 is out. I did some investigation this morning and could not see an obvious way to replace the bulb. Before I go any further, if anyone out there has changed the bulbs, could they let me know how to get into the assembly?
Thanks, again,
/s/ Chris Kennedy
Bulb Replacement:
  1. Pry light assembly from the mirror at the slots provided on the outer ends of light lens.
  2. Remove clip holding connector.
  3. Replace bulb.
Ken said:
Bulb Replacement:
  3. Replace bulb.
Once again, thank you very much! I will do this, and report back.
Happy fourth!!
/s/ Chris Kennedy
Just a guy in Houston, Texas
hoping to be in San Diego soon.
To wrap this up: I pried out the fixture, replaced the bulb, and the light now works fine. Thanks, again, for your reply and help!!
/s/ Chris Kennedy
