G
George Black
68-82 corvettes have an AC condensation drain hole on the bottom of the evaporator housing box. The hole had a plastic/rubber cap with small opening to allow drainage, but to keep bugs,dirt,debris out. It also kept engine heat from entering into the AC/Evap. assembly; prevented cold AC air being lost when AC was on. It was Group 9.211; GM Part # 3021960; now discontinued. It is not shown in the AIM. It is shown in the GM corvette parts catalog in an exploded diagram in Group 9.
Fix: Go to Lowes. Purchase 1" PVC cap (for about 50 cents!) Drill 5 small holes in cap to allow for drainage. Attach cap to drain hole using adhesive. (spray paint cap black if you want it to look OEM). or, go to www.oldairproducts.com and purchase rubber drain tube/clamp, part # 21-5004, for $8.50.
For photo of GM Part # 3021960, go to Ebay auction no.2478331706 and look at the bottom of the evap. housing unit. It is the small black cap.
If you do not have this cap, turn AC on MAX, get under your car, and feel the amount of cold air coming out of the evap. drain hole! When AC is off, the opening will allow hot engine heat to enter the system, which ends up in your AC ducts/vents--not to mention dirt, bugs, road debris. etc.
Just a tip I thought I would pass along with the hot summer upon us!
