sooperman
Anyone have any experience with the new 15,000 mile Mobil 1. For my last oil change I switched to it along with the Mobil 1 filter.
I'm way off, I was thinking of I'd be safe if I changed the filter every 3,000 miles. I don't understand. What criteria do you use for an oil change?That's what I use. To me it seemed like Mobil came out with the extended life stuff when they had to change the regular stuff to meet the most recent oil standard GF-4 (I think "GF-4" is what it was, going from memory). I believe this had more of an emissions and economy mindset, not a maximum protection mindset behind the standard.
I figure the Extended Life M1 is what they offer as their best protection, and that's why I use M1 in the first place, so that's what I put in the ZR-1.
I don't go 15,000 miles on oil changes, though. So far I haven't even gone 3,000 on any, though that's my target.
I'd go 3,000 miles. But I've changed early once due to treplacing the injectors. Figured in case any fuel leaked into any oil passages or whatnot, just to be safe. And once the "change oil" light came on so I changed it, though it was probably from disconnecting the battery and such. I've only had the car about 1.5 years and put ~4k miles on it.I'm way off, I was thinking of I'd be safe if I changed the filter every 3,000 miles. I don't understand. What criteria do you use for an oil change?
