bobmanx
- Joined
- Dec 29, 2002
- Messages
- 169
- Location
- Southern Calif.
- Corvette
- 1967 White Convert. 327/350hp, 4 spd, with A/C
Is there anyone out there in the mid-year Corvette world that has any ideas as to where the moisture is coming from on the underside of the front floor mats? The carpets are dry to the touch and moisture doesnt show when placing "Service Station Type" paper towels on the carpet in both of the front foot areas, but the other day after running the 67 Convertible with the top down about 50 miles round trip with the A/C OFF, there was moisture droplets on the underside of the vinyl floor mats.
The top was down and the weather was in the 90+ range. The radiator hoses are new and the level did not drop in the expansion tank after cooling off. There was not any visual moisture lines under the defroster box area and the moisture was under both of the front vinyl mats. Car has been garaged for several years in Arizona so I'm sure that it hasnt been in the rain. and I havent washed it, so there shouldnt be any cowl drain tubes that have plugged up and allowed water into the front vents.
So I'm open to suggestions or ideas on where to look. To rule out the defroster/heater coil, what is the best way to by-pass it? plug the lines at the firewall or connect the in and out together to allow the coolant to still recirculate thru the hoses minus the heater coil?
Could it be condensation, the day was rather humid and the exhaust pipes are near the center of the car as it is a rear exhaust.
Anyone been here before and what did they find?
Thanks for all of the previous answers and help on trying to straighten out the kinks and bugs. Since the car is original, and not wanting to ruin anything, its sitting in the garage awaiting a solution or things to check.
Bob
Bob
