Ed's 1970
Hello guys,
My big block 540 is coming along. I have the bare block (bowtie gen 6) and most of the rotating assembly. Motor will be built this summer. I don't know at this time when it will go in, there are some issues with my car's suspension that have to be fixed before putting this beast in it. As it stands now, the car won't be able to handle it, if I put the motor in now, it would be pure insanity. What I really want to do is get the shell off the car and just redo the whole chassis and put the motor and other stuff in then. It's looking like the 540 I am building will put out 550-600 horse, and 650-700 tq, although it is capable of much more. I am just going to tell people it's a 454 , u can not tell the difference.
There are some other things I will need as you probably already know. One of them is an upgraded aluminum radiator. Are the radiator supports different on a small block car? Will I have to swap out the radiator support in order to install a big-block radiator?
The other question I had was the tranny. I think I need a rockcrusher, M22 or a heavy-duty 5 spd from tremec. Seems like the M22 would be much easier, although it only has 4 gears. Any suggestions?
The other parts of the drivetrain: I already bought some heavy-duty 3.0" half-shafts and chromoly strut rods. I plan on getting a heavy duty 3.0" driveshaft as well, the stocker looks weak to me!
The exhaust: I am thinking headers with stock routing to the back, but 3.0" polished stainless steel tubing with some 2 or 3 chamber flowmasters.
Thanks Ed
Thanks Ed
