DanC
When I changed the coolant in my 93 LT1 last August, I was able to purchase coolant that met the General Motors spec 1825-M5 that's noted in the factory service manual for this engine.
Just got back from shopping for coolant, and the specs on the package now are mostly "Meets ASTMD-3306 and ASTMD 4985".
Found one that also had "GM1825M" with the others (the 5 is missing at the end, significant??).
With all the horror stories floating around about DexCool and others with compatibility problems, what do I use to top off the system?
Are the new specs similar to motor oil ratings? Backward compatible?
I'm so confused...
Thanks,
I'm so confused...
Thanks,
