D
Da Hawaiian Punch
Aloha Sir C-4/5 specs. I'm getting a '85, Dana 36 rear end, will I have any diffilculty in swapping it out to my '91 vette? Will I just be able to take the 2.59 out and put the 3.07's in,with no problems? and will I be able to use the same speed sensor? Mahalo's!! (Side question about that problem my friend was haveing with that sensor again!) the one that you said for him to check to see if the wire was stretched before replacing the sensor? I hope you remember, it was on the C-5 side that I wrote the question. anyway, he would like to know the voltage it should read when he checks the wiring to locate which one was stretched!! Thanks again!
