- Joined
- Aug 29, 2001
- Messages
- 3,239
- Location
- Norcross, Georgia, United Stat
- Corvette
- 2017 Arctic White Grand Sport
I'm looking to start working on my ignition system and am considering this unit. While the ignition system model seems fairly simple, decisions on the which coil and accessory wiring harness is confusing me.
Is Blaster GM Coil, PN 8226, the direct replacement for the stock coil? It says "This style coil was used on pretty much anything that came out of GM until 1996 (except DIS systems)" but it doesn't seem to be the right one. It references two connectors, usually one gray and one black. Mine has three connectors, a black one that goes to the bottom of the distributor and a brown and white one that seem to be the positive and negative for the coil. If this isn't the correct coil, can someone tell me which one is?
MSD sells accessory wiring harnesses that seem to make the installation go much easier, pretty much plug and play. Part #8876 looks to go with the above mentioned coil plugging into the end of the existing connecter that goes into the coil with the other end plugging into the coil with all of the connectors for the MSD unit.
If the referenced coil isn't correct, which harness would be correct?
