A
Alfonso Gomez
OK, here's the deal. Since the headlights in my 87 Coupe did not rotate, I did extensive testing as per forum member's recommendations. Found BOTH motors were damaged. They were in a really crappy condition since water somehow entered them. So I went to a local GM parts distributor and ordered the upgrade kit (like the one Mid America sells) to use 1988-90 motors. The 1984-87 motors are relay-driven (3 relays). 1988-90 motors are driven by a module. I read the instructions TWICE before begining the installation. The relays were eliminated as per the instruction manual, all splices were checked twice against the instructions, all work done with the battery disconnected. When finished, I turned the headlight knobs to manually close the headlights, connected the battery and turned on the lights. VOILA!!! The headlights opened. Nice, very nice. But when I switched them off, the headlights turned off but THEY DID NOT CLOSE!! So I disconnected the battery and rechecked all the connections and splices to make sure they were tight and correct according to the manual. They still open but do not close.
Any forum member tried this conversion kit? How can I trouble shoot this problem? Please help. This kit costs almost $600 and my car still looks the same with the lights popped open.
