- Joined
- Mar 6, 2005
- Messages
- 1,074
- Location
- Trois Rivieres, Quebec, Canada
- Corvette
- 63 Resto Coupe-Red 65 Roadster
I'm up in the air with this @#$%&* lift.
I have just recently purchased a new lift for my garage, and things are not going as good as I had expected. I settled on a " Bend-Pak ", model SP-7X model, purchased it from " Automotive Services Equipment " in CA, and after having waited more then 5 days after it was promised, it finally arrived a week ago last Friday.
I set it up myself in a few hours, after having gone through the poorly written instruction manual at least four times. Then during the afternoon I was finally able to hit the " up " bottom to have it gently rise off the floor. Then in order to service it, and grease the assorted rollers and tracks, I pressed the " down " button, only to get no response what so ever from the lift. I believe an appropriate term would be " dead in the water ", zilch, na-na, nothing going on.
I checked out all the various hook-ups, and found that according to the wiring digram in the manual, two of the wires coming from the " DN " switch, had been reversed from the factory. Well as you already have probably guessed, when I reversed the connection, it had no effect what so ever on the operation.
I then ( late Friday ) got in touch with the seller " ASE " only to be told that they do not have anything to do with the service, and that I should get in touch with the manufacturer Bend-Pak. A phone call to their offices put me in touch with a recording asking me to leave a message. Well I told them that I had a mal-function, and that because of the position ( check pic ) of the lift, it had become an emergency for me. Well as it turned out the weekend passed, along with a good portion of the following Monday before I was able to get a response.
Their tech support, diagnosed the problem as being an electrically controlled solenoid, and I was asked how I wanted this to be addressed. I told them that if they could overnight the switch to me I would gladly replace it myself. Well here is where the fun starts.
I was told that I should expect the package the next day with UPS. When two days had passed, and still no switch, I called and was able to obtain the " waybill " number, only to realize that it had been sent " Standard " . All this time the lift was in the garage door opening, and I could no longer get any cars in or out of the garage.
I then called the factory again, and was told that a mistake had been made in the shipping, and that a second switch would be sent out immediately, and that I should expect it the next day. As it turned out , this also was a load of crap, because the waybill number showed that rather then being sent " Express next day " it was sent " expedite, with a two day delivery, or four to five days if it falls on a weekend.
It has now been nine days since the lift is in the doorway, stuck in the up position, and still no packages. After doing more then a few traces, I was finally able to see where the boxes were.
The first shipment took five days to travel from Ventura CA to Los Angeles CA, and as of the last Friday the 5th, it has not moved from LA.
The second box was sent out last Thursday the 4th from Ventura, and is still in transit after four days. See below the various details on the shipments.
First shipment
5/5/2006 1:08:00 AM EXPORT SCAN LOS ANGELES, CA US
5/5/2006 12:34:00 AM UNLOAD SCAN LOS ANGELES, CA US
5/4/2006 11:27:00 PM ARRIVAL SCAN LOS ANGELES, CA US
5/4/2006 10:00:00 PM DEPARTURE SCAN VENTURA, CA US
5/4/2006 7:24:00 PM UPS INTERNAL ACTIVITY CODE;FORWARDED TO THE FACILITY IN THE DESTINATION CITY VENTURA, CA US
5/4/2006 5:49:00 PM ORIGIN SCAN VENTURA, CA US
5/4/2006 3:34:00 PM THE COMMERCIAL INVOICE IS MISSING AND IS REQUIRED FOR EXPORT;RELEASED BY CLEARING AGENCY. NOW IN-TRANSIT FOR DELIVERY VENTURA, CA US
5/1/2006 9:23:00 PM THE COMMERCIAL INVOICE IS MISSING AND IS REQUIRED FOR EXPORT VENTURA, CA US
5/1/2006 9:19:00 PM UPS INTERNAL ACTIVITY CODE;UPS CONTACTED THE SENDER VENTURA, CA US
5/1/2006 5:50:00 PM BILLING INFORMATION RECEIVED US
Second shipment
5/6/2006 5:06:00 AM IN TRANSIT TO LACHINE, PQ CA
5/6/2006 5:05:00 AM DEPARTURE SCAN LOUISVILLE, KY US
5/5/2006 1:09:00 PM EXPORT SCAN LOUISVILLE, KY US
5/5/2006 1:01:00 PM EXPORT SCAN LOUISVILLE, KY US
5/5/2006 11:55:00 AM ARRIVAL SCAN LOUISVILLE, KY US
5/5/2006 5:21:00 AM DEPARTURE SCAN ONTARIO, CA US
5/5/2006 12:37:00 AM LOCATION SCAN ONTARIO, CA US
5/4/2006 11:59:00 PM ARRIVAL SCAN ONTARIO, CA US
5/4/2006 9:21:00 PM ORIGIN SCAN VENTURA, CA US
5/4/2006 6:16:00 PM BILLING INFORMATION RECEIVED US
In closing, and in all fairness, I am delighted with my new lift, and the overall quality of the unit. As for the support, after the sale, there is only one word for it and it's " Bull-Shît "
Sorry for the long post, but I had to get it off my chest.
Stepinwolf
First shipment
Second shipment
Stepinwolf
