When you start pulling the starter, disconnect the battery!!! If not you can cause more trouble. Does the 76 have a clutch safety switch that has to make before the starter will spin??? I have an automatic so I don't know. Before pulling the starter I would check and make sure it is bad, a lot of work if it is not the problem. quote]
Good Idea, I would of never thought of that. On the clutch brakcet There should be a small wiring connector with 2 wires. pull off the connector from the bracket and Get a paper clip and put the two endsw of the paper clip in the holes. Try staring it, if the car starts, you got a bad clutch safety switch.
zachh
