I have a 75 L48 Automatic.
The car had a leaky caliper that was discovered when it failed inspection because the pedal had no resistance (it still stopped but only when the pedal was all the way to the floor). I replaced the calipers and lines and bled the system with a pump bleeder attached to the caliper.
No Dice.
Replaced the Master cylinder because of obvious leaks near the booster. Rebled the system.
Still nothing.
I just replaced the Brake Booster and there is a bit more resistance in the pedal and when I depress the pedal with the M/C cover off I can see it squirt so I am getting something there.
However the pedal still goes to the floor. I also noticed that the pedal is binding on something but there is nothing that looks like it is in the way. I took some measurements. When the pedal is all the way forward it is 7 inches from the back of the floorboard. When you push on the pedal, it goes down 2 inches with no resistance and then you get the resistance where I assume the pedal is actually moving fluid. Release the pedal and it only goes up 4-5 inches from the floor (5 being the point where the resistance kicks in when it is depressed). To get it to come up to the 7 inch mark, I have to pull it up manually, when I do that it feels like it is binding or catching on something but I don't know what. I see a red spring at the top of the pedal and I sprayed some white lithium grease all up in there to see if that was the culprit but nothing.
So here I am with an entire new brake system (Pads, Calipers, flex lines, Master Cylinder, Brake Booster, and about a gallon of fluid) yet the problem is still there. There are no obvious leaks anywhere and all the hardline looks fine.
Is there anything else that it could be? I do not want to drive it in fear of nothing working at all (just my luck). If there is anything that anyone can think of to fix this so I can get some brake pressure and confidence in the car I would greatly appreciate it.
Thanks,
Greg Davis
1975 L-48 Auto.
"The white money pit"
