kingman said:
Question can l replace only one?
kingman said:Is the driver's side the high note?
kingman said:Does it make a difference which horn is installed, either the high note or the other one (f note).
kingman said:
If l disconnect the negative battery, will it hurt the car? This might seem like a dumb question, but l would hate to make a mistake.
kingman said:Just thinking, what if l just pull the fuse for the horn's. This would be easier then taking off the neg cable from the battery?
kingman said:
Should l still replace it with a high note or just instal the F note??
kingman said:It looks like there is only one bolt holding the horn and an electrical plug that attaches to the horn. Am l missing anything?
kingman said:Thanks for all of the help. Now l can order the horn from eckler's.
Even though it is the F note (driver's side), l'm going to order the high note unless you think it will sound better with the F note.
Alan
