G
gambit
I have decided to treat myself to a new steering wheel, leather is shot. To have it rewrapped is insane in price so I think I am going with one of the wooden ones that are cheaper and it will match my wood dash / console kit. I need to know how hard it is to get off before I go tugging on things, does the horn button just pop off or is there a trick to it? I dont want to break it. Once i get it off can I just get the wheel off with a nut and bolt or will I need a pulley or any special tools?
I also think I need to change the turn signal / cruise control lever. My cruise has never worked even though I replaced the cables, transducer, and all of the vaccume lines and the thingy on the carb all work ok. after replacing all of that it would accell when you press the lever in and hold it but it never would set. now it does nothing so figured I would try this one last part and see if that is it. Is that easy to replace with the steering wheel off? Any thoughts or comments?
Thanks a million everybody!
