J
JENSHAMMER@HOTMAIL.COM
I'm running a 80 shark with the L48 350, an edelbrock 600 cfm carb and a truckload of troubles. The motor was rebuilt about 6000 miles ago, and the carb installed about 5000. I loaned it out to a trusted friend, who changed the oil, but was running with much too high oil pressure (about 80 psi) for a few hundred miles at the least. He drove it to my place with no problems, and I let it sit for about 3 days before I tried to start it. When i tried to start it, I pretty much had to flood it to get it to run, and I can only run it at about 2000 rpm and higher, if I let it go below that, it dies. There is oil in some of the cylinders, and a few of the plugs have oil on them. (I just changed them after seeing that). It is 'possible" that a small piece of the carb broke off and fell in, long story. If that is possibly related, I dont know. Also, when the engine starts to go below 2000 rpm to die, the carb starts to leak from the plunger on the front drivers side of the carb. Needing desparate help, dont want to pay a shop a ton of money if this is something 2 above ameteur mechanics can do.
Appreciated! Jens
Appreciated! Jens
