6
69vettester
Rob79er said:I am a newbie so I don't really know all of the jargon yet as far as engine talk goes. Here is what I want to do:
I have a '79 L-82 that I have pulled. So far it has only been cleaned and checked by the machine shop. The shop recommends .020 over bore based upon what they saw. I would like to rebuild it as cheap as possible but with a little more pep than stock. I've heard that the stock #624 heads are junk so I was thinking of Vortecs or the Dart Iron Eagles. What Cam and/or Heads do you guys recommend as a combo that will achieve this. I want it to be 100% streetable without a lumpy idle---but fairly quick at the same time.....
I am open to suggestions...thanks
Because your wanting Mild street performance,
I think youll have great results going with GMPP Iron L31 Vortec heads. They are a perfect inexpensive upgrade over stock. They'll take cams that have up to .450 max lift.If you want to use a higher lifting cam than that , youll need to be shopping for one of the others like Dart mild performance heads or Edelbrocks ect. Theres alot of vortec intakes available now, GMPP has a great vortec intake but its a hi-rise for the 375HP to 450HP, higher flowing aluminum and iron vortec heads and wont fit under your hood anyway. They have a lowrise manifold too, but its priced high compared with the Edel. performer air gap vortec intake. Its a Lowrise and would Probably be ideal with those mild GMPP vortec heads, I would think.
Whatever cam you get, It needs to have no more than .450 max lift to work with this GMPP vortec head. Comp, Crane, and edelbrock all make ideal dual pattern cams in your range, that is: duration@.050 206/212 , lift 435/445, rpm range 800-4600.
Scoggin Dickey's website is a good place to shop and get familiar with engine combos.
Summit racing is too and Pace and Sallee.
You can become an engine combo pro browsing these sights,
Good luck, Post pics if possible...
