cntrhub
- Joined
- Jun 17, 2002
- Messages
- 390
- Location
- North Hollywood, Ca.
- Corvette
- Miss my '62 & '80 4- Sp. Vettes
I'd really like to hear everyone add their personal opinion, professional opinion, or any opinion in general, about using an anti-seize compound on spark plugs.
I know there is a big debate of this and maybe nothing will come of it, but I would like to hear some logical input dealing with the pro and con of this issue.
I know aluminum and copper are not too friendly to each other if you do a little research on "galvanic action".....but I assume this is ignored and the compound continues to be used on aluminum heads.
Short of the Bean Counters having their say at GM, how is it that if this was such "the cat's meow", why isn't this being done on the Corvettes which have such a low production run from GM? You would assume because this is their prized sports car, they would give the car enthusiast every possible advantage for performance.
Wouldn't you have a better chance cleaning a dry spark plug hole with compressed air, than you would with remnant seize compound left deep inside the thread hole? If anything, the chances of dirt being "pushed into" the compound, rather than being blown away, tends to be the more obvious dilemma here. Now you have this grit crunching down into the threads, snowballing aluminum off the thread pitch, and creating something you wanted to avoid in the first place.
Then there is the subject of 'heat transfer' of the plug to the head. Would not the compound interfere with this process?
Your comments please.
