B747VET
I'm pretty good with most mechanical automotive issues that aren't overly complex. But, I've had a couple of oil related issues with my "new" 2002 C5 that really have me puzzled. It has 21,000 miles and was, superficially at least, always babied and extremely well cared for - the car is virtually immaculate. Maybe these oil issues related below are just anomalies but I would really appreciate a little help.
I decided to do a new Mobil One oil & filter change. On my previous '94 C4 ZR-1 and '89 C4 Z-51 I always used Mobil One 10-40, 15-30, or 20-40 and never had an oil related problem of any kind. Back then there were numerous warnings from experts that Mobil One 5-30 was prone to sudsing. (Back then, Dick Guldstrand's shop did all the work on my ZR-1.)
I took the C5 it to a reputable big name Corvette specialty shop (not Guldstrand) for the oil change on top of a few other improvements. They said 5-30 or 10-40 and I went with 10-40 because of my past experience with the other Vettes. Oil filter was the blue GM. On the freeway ride home everything seemed fine.
Next day I made a few high speed slalom and road course type runs doing 4500 to 5000 RPM's on several segments. Nothing over 90 MPH. I shut it down for a few hours and then got an engine warning light when driving to the airport to pick up the wife. It went away after 10 minutes of easy driving. 30 min later it came back again while driving easy.
I pulled into a Mobil station to assess things and started with an oil check. (Note: On the previous runs, oil temp never exceeded 220 and mostly was at 190-200 with OAT of 75 deg F. Oil pressure seemed to get a little high a few times at 55-60.)
Anyway, when I pulled out the dipstick to check it, smoke was wafting out of the dipstick tube and there was no oil on the dipstick. (I got a little worried) After 15 mins, still no oil on the dipstick. I'm thinking, "Boy these engines really do suck oil at high revs." So, still a little worried, I decided to add a full quart of Mobil One 10-40. After 5 mins the level was at the bottom mark on the dipstick so I decided to drive it home easy.
Next morning, the oil level was about 3/4" ABOVE the max fill line. I started it up and idled awhile, waited 10 minutes and oil was still at the same overfill level. I pulled the oil filter and put in a new one and it still shows 3/4" high. Engine was also running ever so slightly rough. I could feel it straining although RPM's were OK and temps and pressures normal. I decided to do it all over with a new Bosch filter and this time using 5-30. Did some normal runs and then some high rev runs and all seems fine. No sign of a blown seal and the engine is now maintaining an even strain. It just feels much better. The stressed sensations I felt before are gone. Oil pressure seems to be 5 or 6 lbs lower at all RPM's than it was with the 10-40 oil. Pressure only gets to about 50-52 at 3500-4000 and all temps hanging around 190. The dipstick now always shows a normal oil level even after a high rev run and no smoke coming out of the dipstick tube.
So, does any of this ring a bell? Is it possible that 10-40 Mobil One somehow drives this hi torque hi rev push rod engine a little nuts? Other than that, I and a couple mechanics I know are all shaking our heads. Just thankful everything seems OK.
Any thoughts or experiences on these issues would be hugely appreciated...
