Dave's LT-1
I looking for help from the knowledgeable LT-1 experts like rainman, tomtom72, stingray70, etc. I have previously posted under pulse amplification box and am looking for help deciding on whether to buy a supposed 1970 LT-1 convertible that if it really is one is in need of serious help. I have viewed the car a couple of times, each time after checking this forum for more info. which has been very helpful. From what I have found out everything from the tranny forward has been replaced. Should I stop right there and look for something else? The engine #14016379 and cylinder heads #462624 are from ’79. Possibly a crate motor. The aluminum intake is Edlebrock, not GM, the carb is a Holley but not from ’70. There is no A.I.R. pump on the car, no amp box, or even the three holes where it should have been. A lot of other stuff in the engine compartment is replaced or incorrect. The tranny codes out, matching vin, M21 casting #POH23B, which I decoded as 06/23/70. The car’s trim tag is G02 which I believe means assembled 07/02/70, this makes sense as the vin is in the 14100 range out of 17316 built. The frame’s vin matches, I checked the stamping behind the driver’s side rear wheel. The frame is in O.K. shape, surface rust behind rear wheels and surface rust under front clip, not too bad. The exhaust manifold #s right side #3932461, visible if my pic’s come through, left side #3872765, were only on LT-1’s, (late 1970 and 1971)? Exhaust is 2 ½’ swagged to fit into the 2” opening of exhaust manifold. Body is pretty rough, drivers side rear fiberglass been replaced, tag looks like it has a date of ’78. Poor fit and poorly repainted. Trim tag says Bridgehampton Blue, car is red. Convertible top been replaced, looks like from ’78. Current owner says he also has the optional hard top but I have yet to see it. I tried to view tank sticker by pulling back rubber around filler and could see remnants but couldn’t read it as it is covered in dust and dirt. I probably won’t be able to view it or what is left of it unless I drop the tank. I’m sure the current owner won’t let me do this. He has very little knowledge of the previous owner or even what he was buying some 15-20 yrs ago but since it does have the correct tach, console badging, and hood, (I know all of that can be replaced), he’s convinced it’s the real deal and wants about $15K as is. I don’t know what else I can decode or even if it’s worth it. I know a could get a more ‘correct’ motor, intake, cylinder heads, etc. but would that make this car worth it? Anyone know the NCRS stance on doing this? Hopefully some of my pics will come through and look forward to some opinions from current/former owners of ’70 LT-1’s. Thanks in advance of your help.
Dave’s LT-1 (maybe)
			Dave’s LT-1 (maybe)
