J
		joefloyd
I need help installing a kill switch to disable the distributor for theft reasons. Can some one tell me what wire to send to the switch? I have an 80 with the high energy dist, on the side there is a connector with 2 wires, one is a primary gage orange in color and the other is secondary tan in color. I know that on the older dist. with points and external coil they use the full 12 volts in the start position and in the run position they go to a reduced voltage with a resistor or a resistor wire. Does the high energy dist. work on the same comcept, and if it does can i cut the resistor and send it to the switch. I am not sure if that will change the resistance.
Your Help Will Be Greatly Appreciated
Joe.
Joe.
