Dperreault1
Hello all,
Here is my issue.
I had to replace my compressor. I changed the Dryer, Ora-face tube and Compressor. New O-rings on all fittings.
After the change I evacuated the system for 45 minutes. The system held negative pressure so there are no leaks.
I then proceed to charge the system. With the car off I added the first of three Oil+Freon. Each can holds 3oz of oil and 1oz of Freon. The three cans went in fine. I was then able to start the car and allow the compressor to engage, at first there is not enough pressure for it to trip the system.
I then proceeded to add one can of freon, 12oz. After filling with only one can the system was at 29psi on the low side and 215psi on the high side. Right where it is supposed to be. Now correct me if I'm wrong but the book says 9oz of oil and 28oz of freon. Here is the weird part. The air coming out of the vent was holding steady at 60 degrees F. My buddy told me we should not put any more in the system as it could over pressurize and cause damage.
We unhooked everything and I decided that our job was over. I left my buddy's house and on the way home I threw these codes.
U1160-Loss Communication with LDCM
B0432- Body Control Module
B2262- Horizontal Position Sensor Fit
B2264- Vertical Position Sensor Fit
B2265- Horizontal Position Sensor Fault
B0851-Battery 1 out of range
P0153 H C-????? not sure on this one.
I also noticed that the air coming out of the passenger side was still 60 degrees and the air coming out of the drivers vents were only 78 degrees. Here again is the weird part. When I came to a stop light, my vents went down to 60 degrees. As I took off again the warmer air started to come out again. All the while the passenger side was nice and cold.
I know some of you have dealt with this and I'm hoping you can give me a fix for this problem.
First, why only 15oz of freon and the system works at the proper PSI?
Second, why only passenger side getting cold?
Lastly, Why driver vents dropping in temp when at idle?
Thanks for your help.
Dave
Kansas
Here is my issue.
Dave
Kansas
