Hi,
I pulled my steering wheel tonight to replace it with a restored one and found that the sleeve (located on the steering column) that the contact wire for the horn goes to is broken. The sleeve has a channel in it that the horn wire pushes into and then the wire hooks in place under some pressure from a spring to keep electrical contact. Does any one have any idea where I can get this piece or the proper way to disassemble the column at this point?
It's 1992 C4
It's 1992 C4
