J
JRMaroon
Barry,
Something to consider with the jack and stand combination you are looking at is the minimum height of the stands. The heavy duty rating of the stands is nice but your jack will need to be raised near it's limit to reach the minimum height of the stands. To use these stands the car will need to be raised above this lower limit and then lowered onto the stands. I recently purchased a jack and stands and evaluated how the two would work together. My jack raises from 5 1/2" - 22" while my stands work from 13 7/16" - 21".
Good luck,
Jeff
Good luck,
Jeff
although the single biggest factor is the $1000 right now though. Linda's now pregnant so I think my Vette budget has quickly shrunk significantly
