M
majortom75
I'm having some trouble with the passenger window on my '76. The rear side of the window does not seal against the door weatherstripping, causing water leaks and wind noise at highway speeds. This has been a problem since I bought the car a few years ago. Since the T-tops started leaking last year too, I replaced all the weatherstripping hoping this would solve my door problem, but it has not. I found the instructions for window adjustment on a 71 from corvettefaq.com, but my car does not seem to have the inboard/outboard adjustment screw as noted in the diagrams. Unfortunately, I do not have an assembly manual, and was hoping to avoid having to buy one as I will probably be selling the car this spring in order to buy a C5. Any help would be most appreciated. :cool
