K
korea
Need help(1996 LT1 corvette)
Hi guys..
I hope you understand this message..because english is my second language.
I bought my dream vette october last year. I used have a 1996 Pontiac Firebird 3.8 (A4).
i felt totally different bewteen both car. power, handing etc..
I am very happy with My C4.
Anyway My old vette has run good since last october.
bUT now I have a headache problem now.
1996 corvette LT1 coupe(A4) 62,000miles K&N filter.Muffler Eliminater,TB bypass,
When i give my car gas under light throttle conditions, it idles and running is oK But when getting on the pedal hardly(drive or stand) it will pop and hesitate(like knocking sound). this make me crazy stuff. i had it checked up yesterday using GM-OBD2-scanner.
No code was given. No sys light yet
*The engine only has this hesitation when the throttle is quckly opened.(like hard gas on)
*when I start my car start slowly ,it run OK.
* I think this might be happen after flushed cooling system 4days ago. ?
*When engine is cold, RPM rise OK.(even Quick Accelerating in Idle) then engine is getting hot RPM is rise badly in quick accelerlation(with knocking sound)
I checked below list with scan tool but all data was OK.
1. fuel filter
2. opti spark
3. check mnifold gask leaking
4. Mass Air Flow Sensor.MAP sensor
5. fuel pressure check
6. TPS
7. Back pressure check
8, clean the Throttle body
9. spark plug cable plugs
Do you have any idea fix this problem?
*Car only hesitation with popping sound when the throttle is quckly opened at approx 1500 RPM
Hi guys..
1. fuel filter
2. opti spark
6. TPS
