jw15870
I just installed heat shield padding under my carpet. Now, my gas pedal doesn't have enough room to open up the throttle. I have about an inch of play in the throttle cable. If I shorten the cable, I should be able to bring the pedal up, right? On the carb end of the cable, I can't figure out how to remove the terminating end. I can't really get to the cable end that is under the dash. Any insight here would be appreciated.
