Need opinions on '79 L-82
TonyBob5
New member
Durango,CO
Currently Vetteless
Hello, My name is Tony, I am new to this site, and I need your help. I am looking at a 1979 Vette, L-82, factory 4 speed, t-tops, runs well, drives well, no rust, asking $5900, thats the good stuff. Bad stuff- 120,000 miles and he's not sure if the engines ever been rebuilt, paint is faded pretty bad, interior is ok minor work needed there.
So I am seeking advice as to whether or not this is a good deal. A little more about myself- My ex had a 64 Vette that i love and cared for for 8 years and i have been missing Trica (the cars name) since she left 2 years ago. An Alfa could not fill her shoes and the MG did not even come close but they were cars I could afford and I had a little fun with them. Now this C3 becomes available and I am excited, she could never repalce Trica but she could be mine and no one could take her away. So what do you think, Thumbs up or Thumbs down?
Tonybob5,
$5900 is not a bad price for this car, as you described it, but beauty is in the eye of the beholder. I assume you know what to look for to see if it is really an L-82 (electric fan, air pump, VIN) of course these could have been removed. If the car is drivable and the frame is in good condition I'd buy it. Make sure you have enough wallet to fix the car up, my 79 was in reasonable condition when I purchased it, & I'm expecting to put $12K into it before I'm even close to being finished.
Another thing to keep in mind...cosmetics are normally much more expensive to fix up than mechanicals.
If the car has good maintenance records with it the mileage should be less of a concern for the engine. But keep in mind that other mechanicals will likely have that many miles on them as well.
Taking it to a corvette mechanic and having him give it a look over too is another option.
Biggest issues are rust and mechanical problems. Any deep rust on the frame? Crawl underneath.....How are the brakes?..Tie Rods?...Check the rocker panels close to see if any rust underneath them. Any water problems..leakages etc? I guess this will be your daily driver......Interior, if you do it yourself will run $1,000.00 at least to replace. Paint will be a few grand depending upon who you can locate to do the job. How is the chrome?.....Do all the gauges work? I'll bet the clock doesn't..Most older vettes clocks don't work.....But an easy fix......
$5,900.00 seems reasonable. If the motor goes, are you prepared to put a few thousamd into a crate motor for her? Also..Have a MECHANIC, someone you trust have a look at her....Can't hurt, and a second opinion always is good. Check the tires....Any tire rot on the sidewalls?
Be cautious...but make sure you have a few grand to put into the car...
Andy
1976 Milennium Yellow "shark" :)
1979 Greenwood Daytona :D
Hey Tony -
'79 is a good year, I have a black one. Sounds like the one you found is a good deal even with the all miles. At that bargin price you should be able to afford to do some improvments, like Ratflinger and Andy said just be sure you have enough $$ to improve. Mine was $8500 it had a rebuilt motor and new paint, and I put another $2500 just on fixing a window motor, new radiator, hood hindge, tune up, and a couple other 'problems.' I still want to do much more, but at this point is runs great!
I'm new also, so I can't offer much, but these guys here are great and always willing to help if you decided to buy it, and work on it. I passed up a few other vettes and I regreted it later.
Nate
Tony, The price is not bad. You have to plan on spending $$$$$$ on a C-3 to get it back in shape. It's either, spend $12,000 to get one all fixed up or buy it for $5or $6,000 and do the work on it. I chose to do the later and have never regretted it. Ya got to love working on these babies...
Good Luck
Dave
With 120K miles on the engine, it's going to be worn and not worth much. If it has been rebuilt, it's not going to be worth much in the 'collector' arena. I'm guessing that you aren't necessarily concerned about it's worth to collectors as much as it's 'worth' to you. That being the case... I'd consider holding off. $5900 ain't a terrible price, but it's gonna cost a pretty penny to get it back up and looking really nice. Expect that you WILL find problems with it within the first six months. The 4-speed would be the only real attraction to this car for me.
As for the '79 model in general...unless you are truly in love with that particular year, I'd suggest you look at other years. (Sorry, current '79 owners!) The differences just between the '79 and '80 are significant enough to warrant a look at the '80 model, assuming you like the body style. Obviously, I'm a bit biased here.
Here's the same advice I give to everyone looking to buy a used vette.
1) No matter how much you think you've found The One, if you don't end up with it, there will be another "One" just a few months later
2) Buy the most vette you can afford. As someone said above, cosmetic work on a vette can be expensive. Mechanical work isn't necessarily expensive, just time consuming. (If you aren't turning your own wrench, then it does becomes expensive.) If you have $8000 to spend on a vette, and you find this one for $5900, at least look around for vettes in the $8000 price range. It will cost more to fix up a vette than to just find one in the condition you will be happy with. Unless you are looking for a project, I think the object is to find a car you can immediately go out and enjoy, not one that has to sit in the garage awaiting more repairs.
3) If you are looking at an older vette, specifically a '75-'82, don't think that you are going to go out and start smoking ricers. These cars are not fast by any stretch of today's imagination. Off the factory floor they were 8 second 0-60 and top speeds of 124 (give or take). Add on to that 20+ years of being around and mileage on an engine, transmission, etc... you are going to be even slower.
In short, do some really good research and narrow your search down to at least 3 specific years. And focus only on your #1 most loved year. When I started looking, '80 was the year for me. Besides a 350lb weight savings over a '79, I liked the newer body style. '81 started the introduction of computer control and I didn't want that. So 1980 was the sweet spot year for me. Determine what year really makes you smile the most, both from looks and mechanically. Then focus your search on that year.
(If I had to read into your post what you might be thinking, I didn't get the impression that you were 100% ga-ga over this '79. If not, then it's not the car you necessarily want.)
Andy said:
How is the chrome?
Is that a trick question for him? :D No chrome since '73 ;)
TonyBob5 said:
I am looking at a 1979 Vette. ...My ex had a 64 Vette that i love and cared for...
One more thing... there ain't no comparing the two years...At all... other than the name of the car. :D
Specifically, how is the chrome around the windshield..does it need replacing?
I say thumbs up,on my tired 90k+mi, 78/l82/4sp i can still put down the rubber to redline in 1st,decent amount in 2nd,nothen in 3rd or 4th put she's still pullen like a mother.It aint much to look at,but a lot of "bang" for the buck! Between the cost of the car,fixen only what needs be & parts from Jegs etc,Im under $10k total.Got about the same $ amount in the 85.
BUY IT! If you want speed, and power. About 3 months ago, I bought a 79 L82 with alot of rare options for 10,000$. Good cond. just needed an engine overhaul and moderate suspension work. Its worth it, they lay rubber down like you wouldn't believe. Be careful though, once you start working on it, you're noy gonna wanna stop!
zachh
zachh
If you want speed and power, a '79 vette is NOT the car for you. These cars did not have very high hp ratings at all.
TonyBob5 said:
...I am looking at a 1979 Vette, L-82, factory 4 speed, t-tops, runs well, drives well, no rust, asking $5900, thats the good stuff. Bad stuff- 120,000 miles and he's not sure if the engines ever been rebuilt, paint is faded pretty bad, interior is ok minor work needed there.
So I am seeking advice as to whether or not this is a good deal...
Unless you have your heart set on this particular car, you should shop around.
The C3 Vette is an American classic, and the 79 will certainly turn heads. It's good time now to buy one of these beauties while they're still relatively affordable.... Just be wary of rust. C3 Vettes are suscpeptible to rust in some critical areas that can lead to major woes later. Check out the frame area right in front of the rear wheels. Also check the windshield pillar posts. I've read of a test you can do by running a white index card around the inside of the windshield frame to check for rust.
I agree with zachh, be careful as your Vette restoration can be addicting... and you'll easily spend thousands in the process. I wanted to simply put on headers last March, and ended up doing a complete front end rebuild and engine/transmission overhaul!
Well with any unrestored used vette your gonna have to fix replace something, thats to be expected.The L-82 was 220 net hp if I recall correctly.Also If in fact its still the original engine that should be a plus since the L-82 was more or less a detuned LT-1. Id say buy and have some fun with it.Im with the others if the frame is good and the windshield area is sound it sounds like a decent deal.Best thing is drive the car take somebody with you and look it over good and go back again and look at it while you have time to think about what is good and bad about the car.
ratflinger said:
:r
Bah, humbug!! A 383 cures everything!
No doubt about it. But you're talking some serious cash, and it sounds like there's a lot of other stuff that needs to be done.
On the other hand, I say jump on it for $5900. Not too many "running" vettes out there for that money.
Buy it!!!
Enjoy it. Love it. It will treat you badly and dump you.
Then she will beg you to take her out and beat her some more.
Mine has 157,000 on it now, but I've done LOTs of work on her.
You will, in time hate her, you wont let her go, again.
I'm talking about your mistress, 79 Corvette, that you will buy.
http://www.rogerscorvette.com/free/lintini.htm
That is why I went with TPI and a tranny sawp!!
I bought my old 78 for the same price as that 79.
Great car. I sold it for more than twice waht I bought it for when I was done with her.
Have fun!
