srs244
i'm re-doing the entire interior of my 78 pace car and could use some help identifying a part i can't seem to locate in the AIM (or on the wiring diagram i have). there is a relay/switch?? mounted on the top of the tunnel just in front of the rear brake cover support behind the handbrake assembly. it has two plug attached to it. the top is wired with yellow, orange and black wires. the black wire is grounded to the cover support and the other 2 wires run along the passenger side of the tunnel up under the dash. the lower plug (mine has been cut and there aren't any matching wires that i could find) is wired with 3 wires. green, white and grey (which might be dull purple instead of grey). what is the part, and what is the function of the connection that has been cut on my assembly??
many thanks for the help
