EHS
- Joined
- Apr 22, 2002
- Messages
- 175
- Location
- Sleepy Hollow, Westchester, NY
- Corvette
- '00 Triple Black Convertible
Re: EHS I can get you another 20hp
As c4c5specialist stated, we have tested the car a number of times, both on the dyno and on the road, monitoring the A/F ratio with the Tech II, and the car is not running lean.
Also, the MAF changes made by "tricking " the PCM are temporary, and will only last until the computer relearns the tables, and compensates for the adjustment. Why? Because you are only tricking the MAF sensor, not the O2 sensors. So even if the MAF sensor is fooled, the readings downstream in the exhaust path will be off, and the PCM will start to cancel out the modifications to the trims, until the O2 readings are again within parameters.
As c4c5specialist stated, that affects drivability. The only way to get a permanent adjustment is to reprogram the PCM itself, with a Predator, LS1Edit, or a speed shop that does that work. Given that my fuel trims were spot on, I didn't think custom programming was worth it.
While each car an year is different, we gathered enough background data to determine what the issue was, and corrected it by reinstalling the MAF ends with the screen. For my driving conditions and style, that offers the best performance -- not maximum numerical horsepower, but best all around performance.
On the difference between the LS1 and LS6, when looking at the bottom of both manifolds, to me the differences are clearly visible, to the naked eye.
TODD L GRIFFITH said:EHS,
With your modifications, you must be running fuel lean. My mods. are similar to yours, but do not have any of the problems you are having, because I have fooled my PCM electronically to think I am running lean, and the PCM has compensated me with enough spark advance to make me run 10% rich which translates to the right amount of fuel with all that air coming in. The Mass Air Flow Translator, A.K.A. "horsepower in a box" is what you need...
