vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
So I've looked at all options from Hi $$$$ Big block to David Visal ( this guy has a KILLER BOOK) junk yard queens and everything in the middle.
No Big Block
No 373 or up strokers
( need money for paint, interior etc.)
350/350 is the target motor. that looks like a stocker ( L-82 ) Cars a stick! Do not want to change out the flywheel ( it was NEW and I have a Lakewood scattersheild & heavy duty clutch linkage).
Power band from off idle to 4.5K
9.5 to 1 comp
Forged Crank
4 bolt main
I know I want a roller cam & some form of roller rocker.( open to suggestions here )
Trying to keep my L-82 stock covers.
I know I want Edlebrock aluminum heads. but will paint em Orange (heheheheh)
2.02 intake 1.6 ex around 64cc
When things are done.. I want a low rear end ratio for highway cruzin'. 292 ish,
I'm going with a CARB.. probably Holley 650
Vac secondary, electric choke.
I'll have to breakdown & buy the HEI tach drive distrib.Will the chrome sheild for the ignition still fit with HEI? Or what kits to convert the stock distrib to some form of high output ignition ( without bells & whistles) and no crank drive sensors.
Going to stay with the Rams horn manifolds
Car has AC do not want to doodle with header brackets.
So.. the GM crate short block is about
1350 ish I don't think I can build a better one cheaper ( but you can chime in here).
I'm just not 100% sure on the Cam for 1
Not sure about intake ( for clearance reasons) I have an Edlebrock RPM preformer but that looks to tall for my 73 even with the stock aircleaner.
So that's where we are at.....
Any thought's?
Mike
No Big Block
9.5 to 1 comp
Forged Crank
4 bolt main
Any thought's?
Mike
