Mario93ZR1
A while ago I had a shop replace the standard flywheel of my '93 ZR-1 with a light Fidanza flywheel. The shop warned me about more noise from the drivetrain and I was ready for that.
I have driven the car for about 800km now, including a trip on the German Autobahn and taking it up to 220km/hour while chasing a newer model Ferrari, but the noise keeps giving me the creeps sometimes. The clattering sounds are louder, just as expected, but there is also a more grinding noise that worries me.
It sounds like cog wheels that do not run smooth together (heck, I guess that actually IS the sound), like a machine without oil in it (I hope I describe it good). The sound is sometimes very loud, especially in 1 and 2, but also in 3 in RPM's under 2000, worst in low rpm's. I also hear it with high RPM's: on the autobahn when I took the engine above 4500RPM in 4th gear, the sound could even be heard over the loud Flowmaster mufflers.
Strange thing is that sometimes it's there and other times it's not there. I do the same thing: drive away in 1, 2 and 3 (normal, not hard) and I just hear the rattle. Then later on, I do the same thing: drive away in 1, 2 and 3 (normal) and the grinding sound is back.
:ugh
I checked with the shop that replaced the flywheel and they sent me two cans of new Castrol Manual TAF-X oil (specifications: SAE 75W-90; API GL-4+; VW 501 50) and a tube of Wynn's H.P.L.S. Transmission Treatment (+stop leak) for 2 litres of oil.
Is there a mechanical problem or am I just paranoid? Is it wise to replace the oil with the above oil + addition?
Thanks!
:ugh
Thanks!
