- Moderator
- #1
- Joined
- Feb 25, 2002
- Messages
- 4,318
- Location
- Cleveland, Ohio
- Corvette
- ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
Then: Hooker Competition headers (flat black) and straight back exhaust (2.25" tubing)
Now: Hooker Super Competition headers (ceramic coated), H-pipe, and straight back exhaust (2.25" tubing)
First off, the ceramic coated sure are purdy compared to the old, surface rusted black ones!! (With that out of the way now...)
Differences in headers: Super Comps have slightly larger primary tubes (+1/8" maybe?) and use 18 guage steel versus 16 gauge on the regular Comps. The Super Comps are lighter. The primary tubes are routed differently; they have less angular bends to allow for better flow and thus they don't hug the block as much as the regular Comps did. And lastly, the collectors are about 1-1.5" longer on the Super Comps, so a direct, bolt-in replacement wasn't possible.
Being that I was now going to have to modify the exhaust, my mechanic decided he was going to put in the H-pipe. I was leaning towards X, but...oh well. The H-pipe setup was only $32 versus $100 or more for the X-pipe setup.
Right off the bat, the low end torque increase seemed noticeable. This was somewhat of a surprise as the larger primary tubes on the headers should've reduced the bottom-end torque while increasing upper-end HP. I'm guessing the addition of the H-pipe made up for that loss of torque from larger primary tubes.
The sound hasn't changed too much. The noticeable sound difference comes in the upper RPM ranges (3500+). If you heard my car before, you'd know that at 3500 RPM and higher it had a distinctive POP-POP-POP-POP-POP sound. The sound is now much more constant throughout the entire RPM range. "Smoother" is how I would explain it. More refined. No more POP-POP. It almost gets rid of that carburator sound altogher and changes it to a EFI sound...almost.
What surprised me overall was that typically, in my opinion, the louder the car is, the greater the "sensation" of acceleration or speed. If the actual performance gains were minimal at best, it would have seemed even more minimal due to less sound overall. I expected the quieter exhaust note to decrease the sensation. But even with the smoother tone, the car surprisingly feels much more responsive. Either way, I'll know for sure as I have an appointment with the dynojet on May 14th. It won't be an exact "before and after" since my last dyno run because I've had my carb tweeked some more, but carb tweeks shouldn't make as big a difference as the change in exhaust. We'll see!
I'll post some pics of the exhaust before and after in a few days...maybe tonight even. I'll also update this thread with my Dyno results when I get 'em.
I think I'll sometime miss the rap of the old exhaust setup, but I was getting slightly tired of it anyways. Change is good. And if it brings more performance, that's even more good-er-er!
