WhalePirot
Welcome. You found, arguably the nicest group of cars guys on any forum.
An OP should move this post to the C3 forum, where there may be more attention and answers.
As the sound varies with RPM it's likely related to the tach. AFAIK, you could unscrew the tach drive from the distributor and see it the sound stops. Also, look to see if the tach needle is steady or jumpy.
Are you sure the noise is sourced inside the car? << Vette guys wave at each other, BTW.
