tiger1007
New member
I'm going to build my first vette pretty much from the ground up. For the motor I am torn between spending the extra $ for the fuel injection (was thinking the ramjet 502) and just sticking with a carb. I have an edelbrock in my mudding truck, which used to be my DD, and i never had any problem with cold starts/driveability. It was a little unresponsive if you mashed it at idle, but that's what the clutch is for Also, I've been reading about people putting together older engines with vortec heads. Do all chev V8's have the same head bolt pattern, or do I have to have a specific block? What about blocks set up for hydraulic cams, and 2 vs 4 bolt mains? Any input would be welcome.
I'm going with the 4L80E trans and a paddle shift kit. I know that for sure.
I'm not familiar with the corvette rear suspension. I know my GM 14 bolt in my truck will take the 500+ ft lbs. The leafs in the back jump sometimes, but I deal with it for better suspension flex over rocks. What am I going to need to upgrade to in order to keep a rear end in it, and will the stock suspension setup even hold that much power? What about the half shafts?
My intended use is a winter DD, as I ride to work in the summer, but I also want to be able to go to the strip and stomp my buddies at lights. That's easy enough on the bike.
A little cheer leading: I'm really impressed with this site. The knowledge base and willingness to help others is outstanding. I can offer solid modeling help to anyone who needs it and have a desktop dyno program also. Haven't played with it much, but I'm willing to try.
