00fxd
Just about to go out and start pulling my diff out in preparation for installing the "new" one from "Fast Corvette" which will be here this aft! Can't wait!
What it boils down to is this - when you install the spring to the cover, just snug up the four spring plate bolts; don't torque those four bolts down until everything else is installed and the full weight of the car is on the spring, so it's almost flat. If you torque them fully with the spring unloaded and arched, you stand an excellent chance of snapping off the bolt ears on the cover.IH2LOSE said:Becarefull I know I followed the service manual to the T the first time I had the rear apart.There was some thing real critical about how the rear spring was torqued up to the rear case cover to avoid cracking the rear case cover.
At the time I was doing it 2 fellow forum members had posted pictures of cracked case covers to re-emfasize the importance of doing it correct.
I am sorry I forgot what the procedure was but it was outlined in the service manual.
Isnt that a large range? when I see a range like that,am I supposed to split it and set to 65? I know when I am using a torque range, and torque past the low side I am always sweating that last click to get up to the high side.JohnZ said:The final torque on the spring retaining plate bolts is 55-75 ft-lbs. Anti-seize won't hurt the rubber at all, neither will silicone spray (just don't use any kind of oil or penetrant on the rubber).
IH2LOSE said:I HOPE YOU MADE THE RIGHT CHOICE ALSO
This from a person going from a 4:11 to a set of 3:36'S.
I think we made a good choice
00fxd said:Got stuck tonite, the new housing has the 9/16 spring mount bolts, my old cover had th 7/16 bolts. I'll get some bolts tomorrow, stick the spring in and away I'll be! What years had the 9/16 spring mount bolts? I'm under the immpression that my old housing is out of a '74.
