vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
The hunt is still on
So I would remove the connectors & re seat em.....
Do you have a helper?
Remove gas cap... have somebody turn the key on... do you hear the pump wind up?
If not... when you jump the red & orange on the oil pressure switch... does the pump wind up then?
Still crank but no fire right?
Still No spark?
Your 100% sure on that right?
You have an OLD plug that you are grounding to the block?
I'm thinking Coil.... Oh.. where the Red wire goes in... there is a connector BEHIND that one ( three pin ) make sure that's seated.
I would get ready to mark your wires.. to remove the cap and start checkin things out
in there.
And just for giggles
remove the TACH line ( White wire )
If the Vats is unhappy it will throw a code 46
We need to get spark happening next...
Vig!
Still No spark?
in there.
Vig!
