farne230
My special edition 427 is now two months old, 1600miles. Problems "fit and finish" from the factory.
1. During a heavy rain storm, the drivers window leaks; same as the c5 the overlapping rubber stripping top-forward section 1" overlap, never installed right, bowed out and drips onto my arm. Dealer order parts month ago, went in forgot to order bolts to remove top??, still waiting for them to call back;
2. The radio, switches FM channels when I turn my wheel to the right and the stations move up, also static in the background; Still waiting for them to fix that, test drive did not show proprom driving around the parking lot..
3. Driver door, steel latch on door,, plastic ring on latch to deaden noise, something moves when pressure applied, it moves like a slot, metal sound when you go over speed bumps slowly; part order waiting, service tech, found it, then had to repeat the noise one hundred times now it is more pronounced;
4. Special edition front break vent inserts, loose, bad installation, one replaced waiting on the second part; two weeks now.
5. Noticed the trunk never lines up exactly with bumper, about 1/16" high across, notice it every time I get in and out for some reason, yet it is secure.
The dealership in San Antonio, Texas is Freedom Chevy (also bought the car there), is there anyone from GM who can help make sure they get the right parts and fix these problems correctly, like the factory should have?
Bob Burns
farne230@yahoo.com
Bob Burns
farne230@yahoo.com
