Newbie With Question
B
beachrover
Hello to all. Obviously new to this board and looking forward to participating.
I have a '93 C4 that I am redoing the interior on. Seats and carpet already on order but I would like to get rid of the Bose system while I have the carpet out. Can anyone recommend a head unit that won't require any dash modifications?
Welcome to the CAC! I have an aftermarket CD player in my vette, but I know our interiors are a little different. Anything should fit as long as you get a dash kit from any electronics store I would think. The only problem you might have is with the factory speakers working with the headunit. I know my speakers have individual amps on each speaker. All I had to do is tie the amp wire into the amp output on the headunit and it all worked. Hopefully this helps a little.
Welcome to the CAC! I have an aftermarket CD player in my vette, but I know our interiors are a little different. Anything should fit as long as you get a dash kit from any electronics store I would think. The only problem you might have is with the factory speakers working with the headunit. I know my speakers have individual amps on each speaker. All I had to do is tie the amp wire into the amp output on the headunit and it all worked. Hopefully this helps a little.​
Thanks for the information. Used it and had new system installed today.
And the results were.....?
So...how did it work?
Welcom aboard, incidentally.
Bobby r...
I like your taste in Vettes, Man. :cool
Sorry I didn't respond sooner. It worked great. I actually just bypassed all of the original equipment with a new head unit, amp & speakers. Thank you, good to be here.
