cabbie said:
Well, I checked the heat riser and it is installed correctly. Fuel is squirting into the carb on acceleration, so that seems ok as well. I am in the process of changing the fuel filter, but am having some problems attaching the new filter. I can't get it to keep from leaking on either end. I've put some sealer on the threads, but it still seems to leak. Any tips on how to keep it from leaking? Any suggestions on the sealer I should use on the threads? I'm thinking the sealer I'm using may not be setting well enough.
Thanks for all the tips so far.
The carb was rebuilt by a recommended mechanic in upstate new york. He works on a lot of classic cars, and has done great work on mine. I've now moved the car to New Jersey so I am unable to take to him to check, and I haven't found a new mechanic in my area yet so I'm trying to see if I can get to the root of the problem myself.
Cabbie, my impression is that the problem was probably caused by the use of your thread sealer.
The worst thing I have heard so far in this thread, is the use of liquid thread sealer. :nono I cannot guarantee the starvation is directly related to it's use, but the exact same thing has actually happened to me in the past. After a carb rebuild, the threads were sealed on the various joints with a goo type sealer, and after only a relatively short period, the gasoline caused the excess sealer to deteriorate in the joints and come loose, thereby circulation through the fuel lines and the carb, in a way to cause partial blocking in the various fuel passages through out the carb.
As a result the engine bogged down during acceleration, and at times it even cause a type of backfire, when bursts of fuel passed through the various fuel passages. The fuel you can see squirting through the top of the carb, is not a guarantee that you will not have some limited starvation during acceleration. You would be surprised at the amount of fuel that is necessary to have smooth acceleration at start up.
The only sealer that you should used ( if it's absolutely necessary ) is the Teflon type of strip that you can use by wrapping a few turns around the male fittings.
In closing if my understanding regarding the type of sealer that was used is correct, my recommendations would be to once again have the carb pulled, and disassembled to check for the presence of foreign material in the assorted fuel passages. If you can't have it done by your previous mechanic, remove the carb it and send it out to one of the carburator rebuilders that regularly advertise in the NCRS " Driveline "
Stepinwolf
