Marv02
I have NO check engine Light but I do have a CODE 42.
When I first got the car fired up after installing the new motor, I had a Check engine light for Code 42 It end up being a broken wire I fixed it the check engine light went away the car ran great.
I drove it around for 10 to 20 miles then it started to run BAD missing stalling something was amiss.
Now No Check engine light but I now have code 42 again.
Any Ideas I don’t think it the same wire again could be an Ignition Mod Or what.
The car idles Ok but not the best it ides ok then starts acting up missing and cutting out but not idling.
Driving from a stop not a lot power after 1500 to 2000 RPM’s the power go’s flat like it’s not advancing the timing.
The motor has 340+ H/P and 427Tq It should be able to smoke the tire when you stand on it from a stop It will not.
