jj_long81
hello. well ive got to know if my ecm could be failing. the check engine light does not work. new bulbs and have checked the circuit board for continuity from connector to circuit board. its okay. car runs poorly and the gas light does not work either. last thing that happened was a break in the main ground under the battery. it was so old it fell apart. while i was starting the car it went dead and i could smell somthing burnt. this may have overloaded somthing. so no check engine light or low fuel light and it run but cannot pull codes. anybody know somthing about this problem?
