To echo GM Junkie I found this excerpt that emphasizes what he is refering to:
Well Maybe Kinda Sorta Not Really!!:L
What you posted has to do with the earlier model C4's!!
(84-87,88)
I'm talking about Cleaning and Inspecting All Grounds!!
Nobody ever checks them,and It can only take 1 bad one to make Electronics and Lighting to do weird things and cause feedback to other components!!
Kinda like when your following somebody with their turn sig on and they brake to slow down and the signal quits and the opposite brake lamp comes on/or everything gos out,or you switch to High Beam and 1 H/L go's bright and the other go's very dim,or you turn on the lights and the turn signal indicator/s(Either or Both) in the dash light up dim!!
(Thats usually a Non Existent or High Resistance Ground!!
He turns on his Fog's and the High Beam Indicator comes on,He's getting feedback from a High Resistance or Non Existent Ground!!
As I said,He needs to Clean and Inspect ALL Grounds!! There are several on the vehicle!
Very Front: R&L frame rail below Headlamps.
Left side frame top beside Radiator.(1-3 Wires)
Right side frame top below AC unit.(1-2 Wires)
Behind Battery on frame.(Battery Removal Required 2-3 Wires)
Engine Block above Oil Filter.(Several Wires)
Left side 2nd bolt up on Bell Housing.(Several Wires)
Left side Frame Rail behind Lt Rear Wheel (1-2 Wires)
