no heat?
the water boy
washington pa.
2001 coup dark blue
2001 coup. i have good ac, fan works fine, thermostat was replaced, i cant get any heat from the heater or defroster. any suggestions?
I'm confused. This is the middle of July. Are you really needing a heater and defroster in mid-summer? Assuming they were working, are you sure you'd be able to tell?
;shrug
-Patrick
Have you checked to ensure that heated coolant is getting past the thermostat? (Check the temperature of the outlet hose as the engine warms -- it should get noticeably warmer from a cold start in short order this time of year.)
ok, if its the 2 hoses that are coming off the side of the thermostat housing, then yes they are getting hot. im assuming that there is a flap, or a door somewhere that isnt opening. this would either be caused by 1) door stuck, 2) whatwever controls this door not functioning. any input?
