Tenacious_D
I just had the steering rack out while replacing the harmonic balancer and now I have no power steering boost at idle. If I rev it up to 1500 or so I get some boost. The more I rev it, the more boost I get. But at idle it's REALLY hard to turn the wheel. The fluid level is normal and it's not making any weird sounds. I'm also not getting any errors on the DIC.
Is it just a matter of bleeding it thoroughly? I have turned the wheel back and forth many times, but have not applied a vacuum to the PS reservior. It just seems strange that there would be boost at 1500+ rpm but none at idle.
Thanks in advance for any advice you can offer.
Kevin
2000 Pewter Vert
Kevin
2000 Pewter Vert
