Jerrys95vette
I have a 1995 Base C4 Corvette. The headlights worked fine but the other day after a short 20 mile trip the right headlight motor lost power and would not close. I smelled a burning smell and saw sticky black oil drip from the bottom of the motor. (Very few drops and a very foul oder) I thought I burned it up but it tested fine when hooked direct to battery. The light bulbs work and have not had any problems. Manual turn worked find. No grinding or slippage. The left side only gets short bursts of power and will move one or two inches when I turn the interior headlight switch off and on. By doing so I can get it (left) to eventually close. Checked the Big fuses for L & R headlight motors and they are ok. My multi-meter hooked to the left fuse port for that headlight motor shows a short burst of power to the left motor when I first turn on the headlight switch. (Maybe a second or less) When connected to the right side fuse I get nothing. I then replaced both headlight motors and gears as I wanted to upgrade to aluminum gears anyway (nothing was wrong with the nylon ones) and still same exact problem. Tested both (new) motors direct to battery and they work fine. Then did same battery test to the old motors and both worked fine.
Could this be the headlight motor control module forward of left tire? I have ordered a new one in hopes that it is. I have hear that these have problems from time-to-time on vettes for some reason.
If the new control module does not correct the problem where do I look next? (Interior headlight switch???) Does it control the left & right motors independently?
In Summary; short burst of power to left motor and NO power to right.
What is wrong? These things worked fine for over a month. That’s how long I have owned the vette.
Thank you kindly for any suggestions, tips, or commentary.
