E
ernie d
Hi guys,
My car turned over and started great. Then I just replaced my straight column with a rebuilt tilt/tele column. Now the car will not turn over or start. My first thought would be that the ignition switch that came with the tilt column is bad.
The actuator rod is moving when the key is turned, so I know the ignition switch is getting that mechanical travel input that it needs.
What do you think?
Thanks!
What do you think?
Thanks!
