M
MagikDraggin
On my '04 coupe (27k miles), there is a sound which is reminiscent of how an idler arm with worn bushings would sound like as it clunks and makes a heavy (solid) jiggling sound when driving over expansion joints and sharp irregularities in the pavement surface.
This is especially noticeable while creeping along at slow speeds and I notice that it often times occurs at the R/F wheel area, but also at the L/F as well.
I've had it up on ramps, and on a lift, and can find no looseness in the tie rods, drag link, or any other part of the suspension. I'm at a complete loss as to what could be making this sound.
It makes no difference if I have the brakes applied or not. And it doesn't matter if I am turning or not, the noise persists...only when going over expansion joints and the like.
The only thing that's been done to the front suspension is the addition of a Z06 sway bar (yes it's nice and tight) and lowered on the bolts down to the last thread. And the factory shocks appear to be tight as well, as is the steering gear itself.
It seems to me that this started shortly I had the front rotors resurfaced due to excessing pulsation...but that could just all be my imagination. However, I can make the caliper rock back and forth on the rotor a little by hand, (I thought that was a little unusual), but none of the attaching hardware was loose.
Anyone have any ideas what I should look for? It may not even be in the suspension at all, but that's what it sounds like to me.
