wishuwerehere82
- Joined
- Sep 6, 2003
- Messages
- 2,316
- Location
- Rochester, NY
- Corvette
- Red '82 Coupe,Sebring Silver '98 Coupe
So let me get this straight , the injectors once the car is fired up, they should be spraying the same amount of fuel? Yes, they should alternate, but spray the same amount. and I tried swapping connectors and it did the same. I'm going to try to check the ECM tomorrow, where is it located at?:W
So you swapped the front and rear injector harness connectors to the opposite sides and the problem with the front injector spraying stayed on the front injector? But if you unplug the connector the injector stops spraying? Something doesn't sound right.
		 Good Luck!
 Good Luck!
