vettegirl said:
I just drained my coolant and replaced it after having to put plain water in in a pinch (car overheated while on road trip). I have noticed it is running a little hotter than normal...how do you "burp" the cooling system?
Thanks!
Lauren
Drain and Fill Procedure
Important
If the procedure below is not followed a low or high coolant level condition and/or vehicle damage could result.
1. Park the vehicle on a level surface.
2. Follow the steps below to remove the radiator surge tank fill cap:
* Slowly rotate the cap counterclockwise1/4 turn and then stop. Do not press down..
* Allow any residual pressure, indicated by a hissing sound, to be relieved.
* After all hissing stops, continue turning counterclockwise to remove the cap.
* To tighten the cap, use hand tight pressure only.
3. Open the radiator drain fowl.
4. Allow the system to drain completely.
5. Inspect the engine coolant:
o Discolored -- follow the flush procedure below.
o Normal in appearance -- Continue with the next step.
6. Close the radiator drain fowl.
Important
When filling the cooling system use a 50 to 60 percent concentration with DEX-COOL® coolant.
7. Fill the system through the surge tank opening.
8. Fill half the capacity of the system with 100 percent DEX-COOL® coolant.
9. Slowly add clean drinkable water to the system until the level reaches to the base of the neck.
10. Start the engine.
11. Idle engine for 1 minute.
12. Install surge tank cap.
13. Cycle the RPM, idle to 3000 in 30 second intervals until engine coolant reaches 99°C (210°F).
14. Shut off the engine.
15. Refer to step 3 above to remove the surge tank cap.
16. Start the engine.
17. Idle engine for 1 minute and fill surge tank to 1/2 inch above COLD FULL mark on the radiator surge tank.
18. Install the surge tank cap.
19. Cycle the RPM, idle to 3000 in 30 second intervals until engine coolant reaches 99°C (210°F).
20. Shut off the engine.
21. Top off coolant as necessary, 1/2 inch above FULL COLD mark on the radiator surge tank.
22. Rinse away any excess coolant from the engine and the compartment.
23. Inspect the concentration of the coolant.
