This morning I was following the thread about slow starting and checked my fuel pressure (car cranks a number of times before startin). After sitting overnight, I had about 3 PSI. Started it, let it run a bit, read 36 psi (yes, a tad low for 86). Turned the engine off and back to "on" (but not running) and watched the pressure visibly decrease to about 10 psi within minutes. I'm certain that after an hour it would be back to 2 or 3.
O-rings on the injectors? I may as well have the injectors out and cleaned or blueprinted or replaced or something. Anything else to look at?
I think an adjustable pressure regulator might be useful as well.
Yes, I knew I was inheriting someone else's problems when I bought this
